mystery hose
Old Oct 25, 2009 | 09:10 PM
91_GTA305's Avatar
Car: 1991 Trans Am
Engine: sb chevy's.
mystery hose
So i noticed my idle has been high lately and ive been looking for something to be causing this. i noticed the black little inlet between the runners is missing a hose. whats suppose to go there and can this be the solution to my problem? i can feel it sucking in air also
Old Oct 25, 2009 | 09:41 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: mystery hose
If it's on the driver side between the runners, there should be a vacuum line going to the PCV valve. And yes, with that unplugged your car will idle high.
Old Oct 26, 2009 | 10:09 PM
91_GTA305's Avatar
Car: 1991 Trans Am
Engine: sb chevy's.
Re: mystery hose
How does the vacuum line go to the pcv valve? i see how the pcv valve has the hose running to the bottom intake. but the valve for the vacuum is just sitting on top of the plenum
Old Oct 26, 2009 | 10:16 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Re: mystery hose
This might help, it's a pic of my engine bay. You can see the PCV valve and vacuum line on the driver side valve cover:
Old Oct 26, 2009 | 11:09 PM
91_GTA305's Avatar
Car: 1991 Trans Am
Engine: sb chevy's.
Re: mystery hose
ok i see it now. thanks. but also the bolt between the runners has a little valve too. is it suppose to be there or is it suppose to be just a bolt? i can actually feel air being sucked from there too.
Old Oct 26, 2009 | 11:12 PM
91_GTA305's Avatar
Car: 1991 Trans Am
Engine: sb chevy's.
Re: mystery hose
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
Gordonr1973
Sep 29, 2015 11:59 AM
st.evel07
Sep 19, 2015 09:24 PM
