Relearning Idle on a v8?
Old Oct 27, 2009 | 12:07 PM
bowtieboy42's Avatar
Car: 89 Camaro
Engine: LB9
Axle/Gears: ?
Hey. Ive seen a few threads discussion a way to have the computer relearn idle. However, I think they only apply to the v6?
My car wont hold an idle in gear. I replaced IAC, TPS, all that jazz. The guage cluster is wrong, says I idle out of gear at 1500, but it sounds more like 1000-1100. Recently the car has been starting to idle a little better too. Its kind of hit or miss whether or not it will stall so I usually just pop it into nuetral at the lights.
Also, my car will run like a bat out of hell when it first starts. Spinning tires into third gear. But about a minute later it looses a lot of its umph. I realize this is probably unrelated to the idle problem but its been on my mind recently. Maybe a bad ECU is responsible for both?
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
