87 IROC starter
Old Oct 31, 2009 | 05:16 PM
87_Injected's Avatar
Car: 2010 2LT RS
87 IROC starter
Does the exhaust need to be dropped in order to install a new starter? It is a tight fit. What needs to be done?
Old Nov 1, 2009 | 06:30 AM
Car: 2010 2LT RS
Re: 87 IROC starter
ttt
Old Nov 1, 2009 | 08:00 AM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
Re: 87 IROC starter
Mine's an 86 TPI car but I did not have to drop the exhaust to get the starter out and the new one in.
The problem with starters is always, for me anyway, trying to get the wires back on the starter in that tiny space. Depends on the wires. Sometimes I can sit it on it's rear, nose up in the air, and get the wires on and then raise the back up and bolt it in.
Its been several years since I put a starter on my IROC but it the hardest part of the job to me is getting the darn thing up off the ground and blocked up so I can get to the starter and wiring.
Old Nov 1, 2009 | 08:24 AM
Car: 2010 2LT RS
Re: 87 IROC starter
Thanks for the reply. After doing a search I found that the solenoid needs to be removed first then the starter will come out. This will be interesting.
Derick15
Sep 17, 2016 05:28 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Accerrito22
Aug 23, 2015 07:22 PM
mustangman65_79
Aug 11, 2015 03:17 PM
milk
Aug 10, 2015 06:26 PM
