Heat Shielding Needed?
Old Nov 4, 2009 | 06:23 AM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
I was wondering if the heat shielding between the gas tank and muffler, under the catalytic converter, and over top of the differential is needed. I could see if it has some thermal shielding properties but my heat shielding is metal. I can see if having a nominal effect but nothing significant. I was thinking about putting a layer of real heat shielding on it and installing them.
Thoughts?
Old Nov 4, 2009 | 06:39 AM
Twin_Turbo's Avatar
Re: Heat Shielding Needed?
The metal shield works on the principle that air is a poor thermal conductor, as in such the shield divides the air on both sides and as such keeps a lot of the heat from the muffler from reaching the tank.
Old Nov 5, 2009 | 07:43 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
I would leave them, they do their job quite well. Only reason to remove them would be if they were obstructing something, and at that point, you would insulate the pipe with wrap or ceramic coating
IROCZ1989
Jan 24, 2016 03:55 PM
mustangman65_79
Sep 1, 2015 03:51 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
