weird noise not the smog pump
Old Nov 8, 2009 | 07:29 PM
hawkdriver's Avatar
Car: 87 GTA / G8 GT
Engine: 5.7L / 6.0L
Transmission: auto's :(
I am getting a weird noise from in front of the engine...sounds like metal on metal...but doesn' change pitch or frequency when the RPM changes..just a rumbling grinding noise. I thought it was the smog pump so I took the belt off (5.7L TPI on 87 GTA) but it's still there...I am wondering if it's the water pump...and if it is how long can I possibly drive before it goes out. I have a 6 hour drive coming up in a couple weeks..thanks
Old Nov 8, 2009 | 10:06 PM
hawkdriver's Avatar
Car: 87 GTA / G8 GT
Engine: 5.7L / 6.0L
Re: weird noise not the smog pump
bump
Old Nov 8, 2009 | 10:41 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
try it with all the belts off to see if the noise is from one
of the belt-driven accesories(water pump is the most
likely suspect) sometimes the outer ring of the crank
damper will work loose and wear against the timing
cover
theshackle
Sep 17, 2020 08:26 AM
Cleotiz
Jan 6, 2018 08:56 PM
italiano67
Dec 11, 2016 09:21 AM
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
