Surface Finish - How Rough is This?
Old Nov 11, 2009 | 08:54 PM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
I was hunting for a while for some pics of machined surfaces with known RA values to compare to but couldn't come up with anything. So what are some guestimates of the RA on this block? I am thinking of running the Felpro 1094 which wants a 55 RA for use with no sealers.
Old Nov 12, 2009 | 11:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That's about 300-something.
Old Nov 13, 2009 | 08:36 AM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Re: Surface Finish - How Rough is This?
Thanks, I wonder if I can still run the shim on a surface like that even with a copper spray. I might step it up to the GM composite gasket to be safe.
Old Nov 14, 2009 | 07:45 AM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
I'm with 57k on this one, I'm a machinist and deal with this every day, that finish is at least 300 and closer to 500 I bet, usually ok for pipe flanges with gaskets and sealer but not the deck surface of a engine, the metal fire ring would never seal to that, a pure copper gasket with sealer may work. How old is that block, looks like a crack there by the coin!!!
Old Nov 15, 2009 | 08:18 PM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Thats just some residue from cleaner. I'll go over the deck surface again if I decide to use the block as is. The block is a one piece rear seal roller block so it cant be too old.
Reid Fleming
Oct 10, 2015 09:56 PM
FueledSoul
Sep 30, 2015 09:18 PM
drumstixer
Sep 29, 2015 03:02 PM
Jlanz55
Sep 29, 2015 08:55 AM
tcflint
Sep 27, 2015 05:58 PM
