No Fuel
Old Nov 16, 2009 | 08:33 AM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
No Fuel
After 5 long restoration years, I tried to start my fully restored 1991 GTA. However, when I turn the key the new Walbro fuel pump will not prime. I checked the fuses and wiring and everything seems to be fine. I tried searching and did not find a "silver bullet" solution. Can anyone provide a process that I should follow to identify the issue? Mechanically I am good, electrically I have little experience.
Any help would be VERY appreciated! I want to hear this thing run!!!
Old Nov 16, 2009 | 07:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Did you verify power at the tank? When the engine isn't running, you only get power for about 5 seconds.
Your timed fuel pump relay may be the problem (don't ask me where it is, I don't have an EFI 3rd gen).
Old Nov 16, 2009 | 09:20 PM
wildjyoung's Avatar
Re: No Fuel
I replaced the relay tonight and it did not change anything. I found the fuel pump test connector and jumped it directly to the positive terminal, which turned on the pump. At this point, the relay is new, as well as the fuse, so I am guessing the ECM may be bad. Can anyone verify?
Old Nov 17, 2009 | 10:41 AM
1986 iroc z28's Avatar
Car: 89 formula
Transmission: t5
Axle/Gears: open junk
Re: No Fuel
My friends 91 camaro had the same problem you describe, and it was the ecm, so id say thats the problem.
Old Nov 17, 2009 | 12:01 PM
wildjyoung's Avatar
Re: No Fuel
I just called and Advance Auto parts has a new one for $49, so it is a no brainer to get a new one. It sat in my basement for about 4 years, so chances are that static killed it.
Old Nov 17, 2009 | 04:20 PM
timespy's Avatar
Car: 91 RS Convertible
Engine: Soon to be swapped
Transmission: Memphis performance 700r4
Axle/Gears: Soon to be changed
Re: No Fuel
I had the same problem when i switched fuel pumps. Turns out it was a bad fuel pump sending unit. Ya know the one that is supposed to tell ya how much gas is in the tank..well it does a bit more than that i guess. Expensive dealer part, I found mine on ebay for 90 bucks. Once i put it in all was good in the world except for the problem i poseted about a few minutes ago.....Wife is fed up..please help!!!
Old Nov 18, 2009 | 07:54 AM
wildjyoung's Avatar
Re: No Fuel
Good point but I replaced that too! Everything in my fuel system is brand new. Fuel tank, sending unit, pump, lines, fuel rail, fuel pressure regaulator. So, I am really stumped. I bought a new ECU last night and am going to install it today to see if it resolved the issue.
Good luck on fixing your issue as well!
Old Nov 19, 2009 | 07:35 AM
wildjyoung's Avatar
Re: No Fuel
Problem is fixed! I replaced the positive battery terminal and forgot that there was a jumper that went to a plug. I added this to the new battery cable and plugged it into a lonely male connector which solved the issue. I know how full fuel and used my adjustable fuel pressure regulator to set the pressure at 50 PSI.
Old Nov 22, 2009 | 05:08 PM
Shinobi'sZ's Avatar
Re: No Fuel
Where is the fuel pump test connector at?
Old Nov 22, 2009 | 05:09 PM
Shinobi'sZ's Avatar
Re: No Fuel
Where is the fuel pump test connector at since it is not on the ALDL?
Old Nov 22, 2009 | 05:33 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: No Fuel
Supposedly, it is ALDL pin G
Old Nov 22, 2009 | 09:36 PM
Shinobi'sZ's Avatar
Re: No Fuel
Actually I found that they deleted that in the later model ALDLs and put a Fuel Pump Test Hot lead up by the relay on the drivers side. But I appreciate the help. There is no G on my ALDL...that was the first clue lol.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
