TPS adjustment ??
Old Nov 18, 2009 | 09:48 PM
dylans's Avatar
TPS adjustment ??
my obd is flashing code 22 tps needing adjustment? how do i adjust this and correct it ?
Old Nov 18, 2009 | 11:00 PM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
Re: TPS adjustment ??
If you'd had done a search on "TPS" you'll probably find something like this link:
https://www.thirdgen.org/forums/dfi-...ml#post4347390
or even other threads that would help you out and give you the info you need! Many others will tell you to SEARCH first rather then posting this question, this is my free-bee to you.
Good luck!
Old Nov 19, 2009 | 01:29 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
And you should aways post your model year when asking questions because as in this case;
some model year TPS's are not adjustable
http://www.corvetteactioncenter.com/...and+Idle+Speed
Old Nov 19, 2009 | 04:13 PM
Car: 87 T-Top GTA
"some model year TPS's are not adjustable" See, I did not know that!!! Thank you vetteoz for that piece of info....
Old Nov 19, 2009 | 07:04 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
"some model year TPS's are not adjustable" See, I did not know that!!! .
On the later model TB's ,the TPS position is fixed.The ECM takes the voltage it sees @ at idle and uses that; it does not require a set voltage figure (.54V ) for calibration like the earlier setups do
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Reid Fleming
Oct 10, 2015 09:56 PM
meeklay812
Oct 1, 2015 03:46 PM
FormulaEngland
Sep 30, 2015 01:50 PM
