My budget 350 build
Old Nov 19, 2009 | 02:47 PM
jmat2407's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7 TPI
Axle/Gears: BW 3.23
My budget 350 build
So I had a 89 camaro 2.8l sitting in the yard and decided I'd turn it into a fun little toy for relatively cheap. I had a late 90's model crate motor sitting in garage so decided to use that to start the project off. Also have a built th350 that we use to use over on the circle track that will be going behind this thing.
My receipt's so far:
New cam bearings, freeze plugs, clean block, polish crankshaft- $184.52
Clevite Rod Bearings- $19.76
Spider and retainers- $78.25
Eagle Forged I beam rods- $212.35
Sealed Power Main bearings- $25.15
Oil Pump-$25.15
Assembly lube misc- $29.65
Sealed Power Piston Rings- $34.15
Std Speed Pro Flat Top Hyper Pistons- $86.00
Summit Roller Lifters- $108.00
Comp Cams XR276HR- $230.65
Vortec heads 062, Screw in studs, guideplates, machined for .650" lift, crane 99846 springs good for .600" lift- $500
1.5 Comp Cam Roller Tip Rocker Arms- free with heads
Total thus far: ~$1560. Still got another $400 or so in getting an intake, distributor, and some other things. Cam will be here tomorrow I'll try to get some pics of it, the trans, and the car this weekend.
BTW these pics are taking with my camera phone please excuse the crappy quality.
Attached Thumbnails My budget 350 build-1258661949.jpg   My budget 350 build-1258661970.jpg   My budget 350 build-1258661972.jpg
Old Nov 19, 2009 | 02:53 PM
jmat2407's Avatar
Engine: 5.7 TPI
Axle/Gears: BW 3.23
Re: My budget 350 build
Some more..
Attached Thumbnails My budget 350 build-1258661730.jpg   My budget 350 build-1258661717.jpg   My budget 350 build-1258661950.jpg
Old Nov 19, 2009 | 03:36 PM
Florida85irocZ's Avatar
i like it i wanna see how it comes out, im figuring what i wanna build in 350 from the bare block for my camaro.
Old Nov 19, 2009 | 06:05 PM
bakes85's Avatar
Car: 1985 trans am
Engine: 1969 chevy 350 .060 over
Transmission: 5spd
cool
im surprised more people arent building 350s to put in their third gen, i recently bought a 85 trans am with a 350 in it out of a first gen camaro, and its HELLAFAST, and its 10x easier to work on then fuel injection and computer controlled crap
I like the style of the third gen but i don't like the injection systems.
Old Nov 19, 2009 | 06:11 PM
U.S.Marine09's Avatar
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Transmission: 700r4, 700r4
Axle/Gears: stock
i am definantly subscribing to this thread because i am hoping to do the same for my berlinetta
Old Nov 19, 2009 | 07:19 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I have to ask - where is the kitchen window going?
Old Nov 19, 2009 | 07:27 PM
jmat2407's Avatar
Engine: 5.7 TPI
Axle/Gears: BW 3.23
lol florida= hurricanes. We keep pre-cut plywood for each window, gotta keep them labeled.
Attached Thumbnails My budget 350 build-1258661948.jpg   My budget 350 build-1258661951.jpg
Old Nov 19, 2009 | 09:02 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
This is gonna be good. I'm stuck on what I want to do with my motor build. I can't even decide on a rotating assembly... 350 with a better top end, or 383 with stock top end (for now).
Old Nov 20, 2009 | 01:20 PM
jmat2407's Avatar
Engine: 5.7 TPI
Axle/Gears: BW 3.23
Yeahhh the new cam is in. Also check out my stock parts junk bin.
Attached Thumbnails My budget 350 build-1258744617.jpg   My budget 350 build-1258744735.jpg   My budget 350 build-1258661722.jpg
Old Nov 20, 2009 | 08:26 PM
Car: 1992 RS
Engine: Carbed 350
Wow - I can't remember the last time my junk stock parts pile was that small!
My "pile" now fills 3 boxes under the house, 3 boxes in the screen room, and a real pile under the screen room that's about 3ft tall, and 6 ft in diameter - and I've twice this year literally gave away stuff for free on Craigslist just to get rid of it!
Old Nov 20, 2009 | 08:31 PM
bakes85's Avatar
Car: 1985 trans am
Transmission: 5spd
damn, too bad your not my neighbor. haha
Old Nov 20, 2009 | 08:34 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
how about some pics of the lucky camaro that gets this build?
Old Apr 11, 2010 | 03:21 AM
esp68camaro's Avatar
Car: 86 iroc-z
Engine: 305 tpi
Transmission: 700-r4
Axle/Gears: 3.73 posi
so is this project done id liked to know how it runs?
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
camaro71633
Sep 1, 2015 10:24 AM
Eric-86sc
Aug 24, 2015 09:01 PM
sreZ28
Aug 14, 2015 07:48 PM
