Fuel issue?
Old Nov 22, 2009 | 03:10 PM
rpwils's Avatar
Fuel issue?
I have a 92 camaro that will start fine but after 30 seconds will start running rough like its not getting gas...lops up and down. If i press the gas pedal it will sputter and die unless I pump it. Does anyone have a clue as to what it could be. I have not changed anything on this car besides sparkplugs and wires and the car only has 35000 miles on it.
Old Nov 22, 2009 | 03:56 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Fuel issue?
Have you checked for vacuum leaks?
Old Nov 22, 2009 | 08:58 PM
rpwils's Avatar
Re: Fuel issue?
I have looked for anything obvious
Old Nov 22, 2009 | 09:12 PM
rpwils's Avatar
Re: Fuel issue?
I tested the fuel pressure and there was hardly anything at all coming out. I am very suprised it even starts. If you had a bad pressure regulator would your pressure gauge read low fuel pressure?
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 18, 2015 02:28 PM
