New AC Delco Fuel Pump HELP!!!
Old Nov 24, 2009 | 09:40 AM
ProtoMaster22's Avatar
Car: 92 Camaro RS
Engine: Vortec TPI 412
Axle/Gears: BorgWarner 327 Limited Slip
Ok so last week i replaced the fuel pump in my 92 z28 with a factory AC Delco pump . Now the car runs just fine but heres the deal after driving the car around for a few hours i hear the fuel pump start to moan so to speak, it pulsates and the more you drive it the louder it gets . When this happens there is a-lot of pressure is being built in the tank i do mean A-lot More then normal. Second the car starts to hunt not alot but enought to here it .Third i smell gas all the time .Any help would be great. Thanks
Old Nov 24, 2009 | 10:30 AM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Re: New AC Delco Fuel Pump HELP!!!
it sounds like the vent line going to your charcoal canister is blocked.
Did you hook it back up when you installed the new pump? was your sending unit in okay shape? Is your purge valve connected on your charcoal canister?
Old Nov 24, 2009 | 09:23 PM
Car: 92 Camaro RS
Yes sir I did, my sending unit was just replaced recently .and I checked all lines everything is correct . I mean iv changed my fuel pump a few times but iv never encountered this issue before.
Old Nov 30, 2009 | 12:16 AM
mben92's Avatar
Car: 1992 camar z28 heritage edition
Engine: 305 tpi
Transmission: 700r
Axle/Gears: stock (for right now)
i have the same exact problem i changed my fuel pump and and sending unit it drives me crazy. let me know if u find a soulition cause i was think maybe the pump are cheap and i need a high profance one.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
