Need help with injector problem
Old Nov 24, 2009 | 05:41 PM
harlybo's Avatar
My car will start then it just dies. My friend and I have narrowed it down to the injectors. They start up fine then they lose power, and he said its not on the ground side its coming from the power side. It will stay running for different time lengths also???? I don't understand it has this happened with any of you guys?
Thanks in advance Bo
Old Nov 24, 2009 | 06:46 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Need help with injector problem
It helps if you post the MY of the vehicle along with the fuel injection type.
If this is a MPFI or TPI of the '89 through '92 MY. And still has the stock Multec injectors. Then just swap them out for some decent Bosch units. The Multec injector coils short out which prevents all 6 or 8 injectors from firing. Basically the engine won't run.
Although the problem usually starts with missing, surging, and holding back on the highway. Then progresses until the engine starts to cut out. Then on to a total no-start condition.
RBob.
Old Nov 25, 2009 | 12:13 PM
harlybo's Avatar
Sorry about that its a 1992 firebird with the 3.1 v-6 auto.
Old Nov 25, 2009 | 04:52 PM
southbay08's Avatar
I agree with Rob, the multecs are notorious for coil failure, you will be extremely happy if you swapped them for a set of the bosch design lll's.
bryan623
Mar 22, 2021 06:43 PM
Street Lethal
Apr 30, 2019 12:14 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
tmellott89
Aug 16, 2015 02:58 PM
