What cold air intake should i use?
Old Nov 24, 2009 | 06:40 PM
C_Sander's Avatar
Car: 91 Camaro RS
Engine: Carbureted 305
What cold air intake can I use for my 350tpi?
Does K&N support thirdgen camaros?
I looked on their website, and when I put in the make, model, year, and engine it came up with only oil filters, and replacements for the stock intake.
Old Nov 24, 2009 | 06:52 PM
Stephen's Avatar
Car: 87 GTA
Re: What cold air intake should i use?
For Camaro TPIs, you cab't really beat what the factory already built.
About the only "improvements", would be to pull the fog lights out of the way, but the filter mount base below the filters, run K&Ns & enlarge where the y-piece merges into 1 bround tube. Make that piece bigger, to flow more air.
That's about it.
Old Nov 25, 2009 | 12:04 PM
C_Sander's Avatar
Car: 91 Camaro RS
so something like this wouldnt be compatible?
http://www.aemintakes.com/images/21-8106DP.jpg
or are you saying that the stock is better than something like this?
Old Nov 25, 2009 | 01:01 PM
Stephen's Avatar
Car: 87 GTA
Stock better than THAT one? Yeah.
It may be sealed from the engine compartment, but not a BIG flow of cool air. It could be better.
The stock setup is aimed directly at the incoming air as your driving, creating a "ram air" effect. https://www.thirdgen.org/ramair
Old Nov 25, 2009 | 02:27 PM
Stephen's Avatar
Car: 87 GTA
To further enhace what I already gave the link to, here is a thread showing one guy enlarging where the y-piece comes together, to lead to the throttle body.
https://www.thirdgen.org/forums/tpi/...pi-camaro.html
Combine the 2 & you can't get much better, with just a stock hood on a Camaro.
Old Dec 6, 2009 | 05:21 AM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
This is a nice setup for Camaro TPI's. You modify your lower air box (very easy) and add the ram air kit.
http://www.hawksthirdgenparts.com/ca...mairboxes.aspx
Old Dec 7, 2009 | 04:31 PM
Stephen's Avatar
Car: 87 GTA
Or save $70 & build it yourself, like in the link I already posted above.....
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
