Camshaft Help
Car: 1986 Camaro
Engine: 355
Axle/Gears: 4.55
Camshaft Help
Im working on building a 350 for my '86 Camaro and i need help with choosing a camshaft. The motor is a 350 bored .030 over with about 9.75:1 compression. Stock crank and stock rods. I am planning on using a set of Vortec heads I got from the junkyard. Anything else you need to know just let me know. Thanks for the help.
Transmission: 4L80E/4L80E
Induction system you'll be using, transmission/gear details, what you'll be using the car for.
Car: 1986 Camaro
Engine: 355
Axle/Gears: 4.55
Re: Camshaft Help
im planning on running a 600cfm carb of some sort, not sure what kind yet tho. Im using a th700r4. i want to use it mostly for the street but i want more of a road race style set up. im also getting a gm 12 bolt with 3:55 gears in itfor the rear end.
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
