Does the motor need to come out for...
Old Nov 25, 2009 | 02:20 PM
IROChevy's Avatar
Car: 1989 Camaro IROC-Z
Engine: 5.7 350ci TPI
Axle/Gears: Borg Warner 2.77s
Hello everyone, I've had a 1989 IROC-Z w/ a 350 TPI for about 6 months and im the 9th (yeah, its clean too!) owner. I've noticed antifreeze leaking from the flywheel/torque converter shield and the leaking amounts change from a puddle to drips for no reason, which leads me to believe a bad softplug. I think there is at least one in the back of that particular motor, correct? and if so, will the motor have to be pulled in order to change it? Any help would be greatly appreciated.
Old Nov 25, 2009 | 03:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Have you pulled the inspection cover to verify it's coming from inside the bellhousing? More likely it's being dripped onto the bellhousing, like the heater hoses.
Old Nov 25, 2009 | 04:26 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Does the motor need to come out for...
If it is leaking from there either the trans or engine will have to come out to get access
Old Nov 25, 2009 | 04:37 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
If so, I pick the trans
Later
Old Dec 9, 2009 | 06:20 PM
IROChevy's Avatar
no i never thought of a hose bein way back there ill have to check. thank you. and im getting a shift kit this christmas so if i have to pick between em, ill take the tranny out. thanks a bunch guys
Old Dec 9, 2009 | 07:38 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
there is a hose that goes in near base of dist. . can be a sneaky leak . took me some time to find mine , 30 mins. to fix it . good luck .
Old Dec 10, 2009 | 07:02 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Could be an intake gasket leak as well... there are outlets on both ends of the heads, and cutouts in both ends of the gaskets... see if theres antifreeze running down the head or is pooled on the bellhousing flange.
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
