pinging noise
Old Nov 25, 2009 | 10:40 PM
Justinlf16's Avatar
pinging noise
I noticed yesterday when i was leaving a store my car started pecking not knocking but like a pecking and a pinging noise, no check engine light on oil pressure is normal. So i went over the street and got some oil "was the first thing i done anyways it said good so i added a quart, it didnt stop so i said i better take it easy and get it to the house only being like 5-6 miles away i started driving the speed limit a lil under plus or minus, about halfway there the noise stopped. I thought it mighta been sludge "i know this time i used a differ oil same weight called mobil 1. Anyways the pinging comes and goes in the morning when its cold it starts up. It's comen from the back of the engine kinda in the middle, I'm guessing maybe a lifter or dunno?
Old Nov 26, 2009 | 10:50 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: pinging noise
Pinging in its classical definition means that you have a problem with detonation which is the fuel air mixture igniting before its supposed to a very bad thing that can do a damage. Pecking im not sure as you would have to describe it better maybe make a video of the sound.
Old Nov 27, 2009 | 04:44 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: pinging noise
check your knock sensor. Passenger side of block.
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Randomtask2
Sep 7, 2015 05:06 PM
