using tons of oil at wot
Old Nov 27, 2009 | 07:43 AM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
for a while now my car has been using a ton of oil and im trying to narrow it down.
the problem is only at wot as far as i can tell when i punch it i get a smokescreen out the tail pipes like nothing i've ever seen and the smell of oil in the car. no external leaks. no. 1,7,and 2 spark plugs get oil on the threads and crudded up pretty bad. heck if i have a night where im on the car hard i can put in as much as 1 1/2 qts the next day. no problems normal driving though.
i was able to get a compression tester on the worst plug no. 7 and it showed 170 175 didn't get to the other ones though.
i have a catch can set up after the pcv valve and i do get some oil in it but if anything it is an extremely small amount.
i was told it could be anything from valve seals to intake leak to rings.
motor is a crate zz4 350 carb with about 3-5000 miles on it (never got the speedometer hooked up lol)
am i looking at a ring job? i was praying it's not the rings since it was a crate motor and i figured i didnt have to deal with rebuilding a new dang motor lolol
thanks
Old Nov 27, 2009 | 09:07 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: using tons of oil at wot
intake gaskets can be famous for leaking on the lower part of the port only under hard WOT but usually only after many miles.
If its a crate and the heads/block were machined and intake not it can be hard to seal without machining intake.
Or just even lose intake boltes, bad asembly work...........
If your sure its not rings or vavles.............
Old Nov 27, 2009 | 10:18 AM
Bobbyz's Avatar
Engine: 350 "ZZ4"
im praying it's something as simple as the intake when i got the motor 3/4 years ago i had to change the intake gaskets because the rear by the dizzy was leaking. maybe it didnt seal right. also i checked and 3 of the bolts were loose.
gonna change the gaskets again and hope for the best
Old Nov 27, 2009 | 01:14 PM
Redlinerevver's Avatar
Car: 84
Engine: 360 210 alumium heads
Transmission: th350 3600 stall w/shift kit
Axle/Gears: floater Ford 9" 4.56 full Lw spool
You might want to use some black gasket maker on them with the gaskets to. I have aways had problems just putting the gaskets in dry.
Old Nov 27, 2009 | 02:13 PM
Damon's Avatar
Do you have the right dipsitck in the engine? Run an engine over-full and it'll use quite a bit of oil, especially at higher RPMs when the crank is slinging a ton of it at the undersides of the pistons.
Run compression on all 8 cylinders and see if you've got any low.
Oil leaking past the valve guides/seals wouldn't be any worse at WOT than it would be at light throttle.
Old Nov 28, 2009 | 12:12 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I never have any luck with them china wall gasket, front n back of intake.
Even the good felpro kit ones always squeeze out.
Why even on the TV shows they throw them in the trash and use just regular
black RTV for the front n back.
Old Nov 28, 2009 | 12:29 PM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
thats what ive always done too.
when your tightening the intake down, be sure to work from the inside bolts out in a cris crosing bolt sequence.
junior419
Apr 7, 2025 11:35 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
timonator
Sep 13, 2015 11:49 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
