Engine suffix ID doesn't come up.
Subscribe
Nov 27, 2009 | 01:49 PM
I've got this motor in a parts car and I can't seem to ID it. Have not taken it out yet.
Casting number is worn so I cannot read it. It has an engine suffix on the water pump pad. reads:
V0519DMN
I can't seem to locate "DMN" anywhere on any of the suffix lists.. I'm assuming it is some 350 from the 80s, as it has a passenger side dipstick and '882 heads. Just curious what the original application was.
-- Joe
Reply 0
Nov 27, 2009 | 07:19 PM
Re: Engine suffix ID doesn't come up.
It's not a 350. It's a 267
DMM = 1979, 267 CID, 120HP, 2BBL, L39
Reply 0
Nov 27, 2009 | 07:39 PM
A 267?? Holy cow.. Guess I'll strip the accessories and junk it.
I couldn't locate that suffix anywhere.. Your 100% positive eh? Guess I'll measure the bore to be sure tomorrow. Wow.
Does a 267 use the same balancer and flywheel weight as a 350? Guess I'll look it up.
Thank you!
-- Joe
Reply 0
Nov 27, 2009 | 08:33 PM
Quote: I can't seem to locate "DMN" anywhere on any of the suffix lists.. I'm assuming it is some 350 from the 80s,
Would appear so , there is no DMN listed but all the other sequential numbers are '79 -'81 engines
http://www.nastyz28.com/gm-chevy-cod...s-suffix-4.php
If it is only a 267 ;small (3.50 ) bore and long (3.48 ) stroke ; you might be on to something , nice fuel economy engine for the gas price rises ?
Reply 0
Nov 27, 2009 | 11:00 PM
There are much better choices for a fuel efficient engine. The 267 is one of the worst and smallest V8's that GM produced.
Reply 0
Nov 28, 2009 | 03:43 PM
Quote: There are much better choices for a fuel efficient engine. The 267 is one of the worst and smallest V8's that GM produced.
Took the engine out and the heads off. It's a 350, two bolt main, with .040 over pistons. Looks to be in good shape too.
Pistons appear to be cast OE type. Seller said it was rebuilt 2500 miles ago, and the cylinders seem to back that story up. Might be a good candidate for a 350-400hp street engine.
-- Joe
Reply 0
Nov 28, 2009 | 04:02 PM
Interesting. I quoted the DMM suffix code. I can't find DMN either.
Reply 0
Nov 28, 2009 | 04:10 PM
Quote: Interesting. I quoted the DMM suffix code. I can't find DMN either.
I am also unable to come up with it. It is interesting that DMM, and DMR are both the 267, and the DMN turns out to be a 350.... Ah well, I gave up expecting any kind of logic on these kinds of things long ago.
Reply 0
Nov 28, 2009 | 05:07 PM
Many of the Dxx codes are 305's
Reply 0
Nov 28, 2009 | 08:55 PM
Quote: Many of the Dxx codes are 305's
Passenger side dipstick is 80-85, right? So the block can't be too old.
The casting number is not legible. On the side of the block, and behind the timing cover appears "207" in the cast.
I can't tell who made the pistons. They simply say "0.40" on the top. They are a dish type, with two valve reliefs. Normal rods and a cast crank it seems. looks cast, didn't look up the number.
-- Joe
Reply 0
Subscribe
