400 too much overbore- Can you save it?
I got a 400 block, a 509 casting, in a package deal a while back. Unfortunately it has a pretty fair amount of wear and some rust in the cylinders, and worst of all, it's already been rebuilt and bored .040.
You could probably clean it up and use it but it would'nt be pretty. I'm not even sure that it would clean up correctly at .060. And I know that .060 is kind of pushing it with any block, especially a 400 even though I have run a 400 block at .060 before. But that block started out in a little better shape.
So, my question is, with the siamesed cylinders on a 400 block, can you sleeve the block and rebore to standard or .030 over? Or are the cylinders too close together?
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: 400 too much overbore- Can you save it?
I would wonder what the cost difference would be between sleeveing the current block, vs. simply replacing it?
You might be right. I try to keep my eyes open for good 400's, bare or complete and have managed to grab a couple at fairly decent prices. But sometimes they get kind of pricey.
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
If it indeed comes down that you need a new block, take a look at ebay.
Skipwhite has fully machined to your specs GM Bowtie blocks for $1250.
After the cost of machine work to a used 400 block you will be close to the $1000 mark anyways.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
You would be much, much better off with the new Dart SHP block. Comes already machined except for the final bore size. With a .040" bore I bet the cylinder walls are flexing already let alone with a .060" bore. So you would be burning some oil and loosing power with blowby.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Mine is .060 over.
Depends on how much core shift. You can usually tell looking at the block.
-- Joe
-- Joe
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You can get 8 sleeves installed to bring it back to new specs but in your case, you're open to other options such as an aftermarket or factory replacement block.
If you had a rare numbers matching block and needed it because of it's rarity or requirement of casting numbers then the cost of putting in 8 sleeves isn't bad. For normal use, the cost of getting 8 sleeves put into an old block isn't worth the little more you can pay for an aftermarket block which will be a much better casting. Stay away from the cheap chinese castings.
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
It would all depend on how much power your talking about building
the motor for.
At .060 as long as no core shift problems and not aggresive on power
works fine. Still running into wall flex, center bores especially. Head gasket sealing
under higher comp and heat issues also. Not motor heat but transfer
between already thin center bore walls.
At tear down we would very carefully check and inspect the
motors and learned alot about these blocks.
Also built alot of our older blocks for street use to recoup a few dollars.
After .030 we would stop and put them back into our haulers where alot
of them came from when new.
I'd go Dart or find better OEM. Years ago we were scrounging for good
ones and usable ones were hard to find then.
At that time had any where from 6 to 8 on hand.
70's cars 2- bolts/ Trucks 4- bolts where we got alot of them from.
HTH
Later
the motor for.
HTH
Later
Car: 1989 GTA
Engine: 369 TPI
IMHO .060" is a roll of the dice and the odds are not in your favor.
Have to agree, as I never took one that far with or without
any power additions.
Quite a few running around though.
Later
Later
Car: 89 Firebird
88SS6SPEED
Nov 11, 2015 07:05 AM
