FIIREBIRD TBI flames
Old Dec 6, 2009 | 12:58 PM
88FFCdunkel's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 305 TBI
Transmission: t-5
Axle/Gears: 3.11 no/posi
When driving the car jumps extremely bad misfires shoots flames out of the throttlebody when coming out of a dead stop could this be timing? im stumped. ive changed plugs plug wires cap and rotor i have atemted to losen the distributor to ajust the timing but i cant seem to get anything on the bolt that is strong enough to loosen it i cannot get a socket on it because of the plate under the dist cap. please help
Old Dec 6, 2009 | 08:04 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: FIIREBIRD TBI flames
You're wiring is off - you need to double check your firing order on the plug wires, and also check the continuity on each wire to make sure there's no shorts in them - brand new wires often have shorts. To get the distributor bolt, go spend $10 on a distributor wrench. And timing has to be adjusted with the EST wire disconnected before the car is started.
Old Dec 8, 2009 | 07:16 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
This definitely sounds like a timing issue.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
2012sergen11
Oct 13, 2015 07:38 PM
Gordonr1973
Sep 29, 2015 11:59 AM
