Headlight motor repair
Old Dec 9, 2009 | 12:44 AM
snprrifl's Avatar
Car: 1992 Trans Am
Engine: Chevorlet 326
Transmission: 700r
1992 Trans Am
I just replaced the bearings in the headlight motors but now when they go up or down the motor gets jammed in that position until I manually turn the motor till it is loose then it will go down on its own. But once its down it gets stuck again! Any ideas or suggestions? all wiring and relays are fine.
Old Dec 10, 2009 | 04:45 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Headlight motor repair
just happens.... mine have been doing this for years but its not all the time... once every couple of weeks they will get stuck in the up or down positon. i just crank them alittle by hand to get them loose and then use the switch.
did u replace the nylon tablets inside the housings? these are what cause the friciton to pull and push the headlights... these nylon bushings wear away and cause excessive play in the gears causing the headlights to just get stuck or not move at all. my stuck issue is from the motors turning the headlights to far up or down and cause the swivel bar to go to far and lock itself. I aways replace the nylon bushings bc they are cheap and are the usual problems with these headlights.
Old Dec 24, 2009 | 12:38 AM
snprrifl's Avatar
Car: 1992 Trans Am
Transmission: 700r
Thanks for the Info. I found out it was because the motor cover was cracked near the screw that holds the cap on. I drilled a new hole and used a bolt to tighten the cover down and it now works perfectly. Thanks for the suggestion and your time.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 13, 2015 12:59 PM
