Car has no power, no get up and go.
Old Dec 9, 2009 | 03:47 PM
heff17's Avatar
Car: 89 Camaro
Engine: 383 w/ 450HP
Transmission: TKO-600
Ok i know its not a camaro but my roommate at school has a 96 accord that we were taking to the mall the other day and as we were going up the onramp to get onto the interstate all the sudden the car had NO get up at all.
We pulled to the sholder and the idle was a little rough but it would rev fine in park so we took off and the car would max out at 15 mph. The trans wasnt slipping it just felt like we were towing a trailer and the car had no pep.
We pulled to the sholder again and put the car in park and it idled rough and cut off. After we refired the car it felt fine good idle and we pulled off but as soon as the car got a load on it, it went back to struggling.
We limped it home and had a tow truck tow it home, the check engine light never came on but while we had it in the parking lot i got out of the car and it had a funny smell that i have never smelled before in a car and the tail pipe had a hissing sound. like an air leak, sounded like one of the tools you hook to your air compressor and blow parts dry after you clean them. Strange noise.
Just wondering if you guys have any thoughts on what could be going on since i know alot of guys on the fourm are good mechanics.
I told him my vote is on the ignition system? Or i thought maybe a stuck exhaust valve could explain the air leak sound out the exhaust.
Old Dec 9, 2009 | 05:43 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Car has no power, no get up and go.
Plugged catalytic converter.
Old Dec 9, 2009 | 06:37 PM
heff17's Avatar
Car: 89 Camaro
Thats what ive had a couple people tell me, ill give yall an update and see if this changes anybody's mind or helps the diagnosis.
After the car was towed home it starts up and drives fine. It was driven for 50+ miles trying to duplicate the problem but couldn't.
Old Dec 9, 2009 | 07:02 PM
ploegi's Avatar
Engine: 5.7 TPI
It had a chance to cool..... Crawl underneath (yeah, I know, neat trick on an accord) and thump the cat with something like a block of wood. (you just want it to wiggle, you are not trying to knock it off the car....) See if it rattles. If so, its bad, and the chunks have just gotten into a position where they are not able to readily block flow.
If all seems solid.... It is going to be a bit more challenging to figger out.
Old Dec 9, 2009 | 07:10 PM
heff17's Avatar
Car: 89 Camaro
Thanks, just looking for all kinds of ideas to help him try!
BlueIroc-Z
Jun 9, 2019 03:22 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NBrehm
Aug 25, 2015 11:49 PM
Exxon Limited
Aug 9, 2015 08:13 PM
