Replaced knock sensor and...
Old Dec 10, 2009 | 07:03 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Now I get a code 45 after the car runs for about 10 seconds. Any ideas? Idles and runs fine as far as I could tell, drove about a mile.
Old Dec 10, 2009 | 08:14 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Replaced knock sensor and...
Was it the correct KS for your engine / year?
One size does not fit all
Old Dec 10, 2009 | 08:44 PM
Mr Froman's Avatar
I hope so. The information given to them was correct and it seems identical to the one that was on there. I think the problem has to do with how tight/loose it is, I didn't use a torque wrench. Tomorrow.
Old Dec 10, 2009 | 09:04 PM
Damon's Avatar
Take it out, give it a few wraps of teflon tape and screw it back in lightly. Just enough to seal it up and not much more.
Old Dec 10, 2009 | 11:02 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
There are at least five different types;
all look the same but calibrated differently for SD or MAF ; 305 or 350
Old Dec 13, 2009 | 10:38 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
This is a single wire sensor that uses the engine block for ground return, using Teflon tape on any sensor of this type may keep it from making a good ground.
db057
Aug 22, 2015 08:17 PM
91REDZ28VERT
Aug 18, 2015 10:16 PM
92purpz28
Aug 11, 2015 02:30 PM
gwade12
Aug 8, 2015 08:17 AM
