Car misses/hessitates
Old Dec 11, 2009 | 06:05 PM
maks10's Avatar
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
To make a very long story short, i had my intake manifold gaskets repaired about 2 months ago. Since then, my car has been hesitating and skiping like no other. When im either accelerating slowly or keeping a constant speed, my car starts jerking/missing. It does this all the time! In the past 2 months i have taken the car back to the original shop, also went to a couple of chevy dealers which they didnt have an answer. I have spoke with some fellow site members and have repaired the following:
TPS (adjusted voltage to .54 but drove worse that way so runs like 0.70), Cap, rotor, plugs, wires, coil, ICM, fuel filter, and probably some other repairs that failed to solve the problem.
One side note, for a couple of weeks my car drove fine with the TPS unbolted from the throttle body but still connected to the ECM until recently(this is how it is now). Basically now, the car drives crappy with my set up now and really crappy if it is bolted on the throttle body. Im considering giving up on this for good but wanted to see if anyone could share any knowledge or advice before i do so. Thanks for all the help.
i
Old Dec 11, 2009 | 09:21 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Car misses/hessitates
Have you checked continuity on all the plug wires? They are often bad wires even when brand new in the box. All plug wires seated properly on the plugs and cap? Triple checked the firing order?
Old Dec 11, 2009 | 09:25 PM
maks10's Avatar
Car: 1990 Trans Am
All done, any other sensor to look for?
Old Jul 1, 2012 | 10:13 PM
maks10's Avatar
Car: 1990 Trans Am
dug this up from my old suscriptions in case people have this same problem wanted to post update:
Previous owner had O2 sensor cut off (prob bc headers w/o o2 sensor bung) and programed out
--> member on site sugested installing O2 sensor----> welded o2 bung and found cut wire
***** FIXED since just forgot to update
no codes showed btw
This site is great!!!!!
Old Jul 28, 2012 | 01:05 PM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
THANK YOU. I just bought a tbi truck with the same exact symptoms, started changing the plugs to troubleshoot & eliminate, and noticed the broken o2 wire. I can't beleive it won't throw a code, but it doesn't.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
