Shaft mounted rockers
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
I realize these are way overkill from an operational standpoint for what I'm planning but wouldn't this get rid of the whole narrow/wide, self aligning/non S.A., guide plate nonsense? I'm guessing I'd have to go to perimeter bolt valve covers but would I need tall ones?
http://cgi.ebay.com/ebaymotors/Small...Q5fAccessories
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Shaft mounted rockers
The only time you really need tall valve covers is if you're using a stud girdle or have longer than stock, valves and springs. The majority of stud or shaft mount rockers will fit under regular valve covers even if there's just some minor clearancing required.
Car: 92 T/A 'vert
Thanks. What about the guide plate/self aligning issue?
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
nope. With shaft rockers no need for self alighning or guide plates. The rockers mount on the base which mounts to the head. No movement side to side.
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Skeptic that I am, I would have to be somewhat suspicious of the quality of this setup!!!!! About 1/3 the cost of a Jesel shaft system, is the quality about 1/3 of the good stuff, too???? Definitely an import piece.... For me, I'd have to do the see, feel, touch thing on them before spending any money.... I guess if I had enough engine to justify a shaft system, I'd be for going with a known product rather then something that could be nothing more then a cheap knockoff.......
Car: 92 Camaro RS
Engine: 305 TBI
Yeah for that price it's made in China junk, the hardware would probably never hold adjustment and lead to failure.
Car: 87 IROC L98
The only good quality shaft rocker system is Jesel or T&D. That SBC set is good for a typical street engine but I wouldn't trust it on any kind of real performance engine.
You would actually be better off buying some Comp Pro Magnum rockers.
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
