What year of block?!! Can't find suffix code..
Old Dec 19, 2009 | 07:15 PM
scidav87's Avatar
Car: 2000 Camaro SS, 1987 IROC-Z
Engine: H/C/I LS-1, 383 Miniram
Transmission: M6, 700R4
Axle/Gears: 4.11 35 spool 9", 3.73 10 bolt
Hope this is the right board to post in I need to know if the block is pre or post 1987. The engine code was K0916FSC..i can't find the FSC suffix code anywhere though!! Can anyone help?THANKS! EDIT: Looks like it might b FSO..or maybe FSG, can't tell..but i KNOW its one of those...still can't find it though.
Old Dec 19, 2009 | 08:24 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: What year of block?!! Can't find suffix code..
Very few triple digit suffix codes start with an F. Actually there's very few F suffix codes.
I see very little choices of alternatives for an F.
E, B, R, P all show little choices for a possible match.
What side of the block is the dipstick on?
Does it use a one or two piece rear main seal?
What's the casting number?
Old Dec 19, 2009 | 09:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
The casting # is all you need. Post that.
Old Dec 19, 2009 | 11:39 PM
scidav87's Avatar
The dipstick is on the passenger side. I THINK its a one piece seal, but its been a few years since i've had the tranny off...the casting # is not visible (grease, dirt, air hose and wires in the way). Looks like i'll need to pull the intake and see if its tapped for the spider maybe?
Old Dec 20, 2009 | 06:52 PM
five7kid's Avatar
Crawl underneath and see if the last three digits of the casting # are cast into the side of the block.
Old Dec 20, 2009 | 07:14 PM
Jeffs82TA's Avatar
You can't trust the suffix code all the time. My 90 vette has a over the counter motor with a suffix code that comes up as a 80 truck 350, however the GM part number where the bellhousing bolts up comes up as a 87-91 roller cam motor.
There is also no VIN number stamped on the pad where the suffix coded number is.
Infested
May 22, 2018 11:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
Reborn756
Sep 4, 2015 03:42 AM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
sreZ28
Aug 14, 2015 07:48 PM
