Throttle position sensor
Car: 88 IROC Z
Got my 88 IROC a week ago,check engine light was on.Got a scanner and it says TPS voltage low.Pulled it up and it was only .19 volts,read it was supposed to be.54 Tried adjusting it but can only get to .35 before i run out of adjustment slot.It looks like a new part. Do i slot it out? do i need to adjust the stop screw on throttle body? It still has the plug in it.Looking for some advice.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Throttle position sensor
Your old one is probably worn out. Replace it.
0.54v is fine. 0.50v is a perfect setting but anywhere from 0.045v ~ 0.055v will work.
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Yes, I agree with Stephen. It sounds like your TPS is bad, replace it. BTW: I have my TPS set at 0.60V. Make sure you buy a TPS with slotted mounting holes so that you can adjust it.
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
I replaced my TPS on my 91 GTA but the sensor was not slotted, therefore non adjustable. Did they change the TPS on the speed density systems?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 82 Z28
Transmission: T400
Car: 88 IROC Z
Thanks guys,will do.
TheTraut88
Sep 7, 2015 05:22 PM
