350 heads
Old Dec 23, 2009 | 09:51 AM
t5535's Avatar
Car: 87 Trans Am
Transmission: 700r
Axle/Gears: ones that turn
350 heads
What is a good casting number for heads?
Old Dec 23, 2009 | 02:02 PM
Blaize's Avatar
Re: 350 heads
there are lots of good ones out there and it depends on what your doing with the engine and car. some good ones to look for are 416,601,062,906,462's all of these numbers are the last 3 digits of the casting. search the site for info and check mortec as well. hopefully some more knowledgeable people can give thier advice also
Old Dec 23, 2009 | 02:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There are some decent factory castings out there, but there are a lot more really bad ones out there.
One important thing you didn't tell us is what you expect out of this engine.
Of the casting #'s mentioned above, 416 and 601 are 305 heads with 58cc (or smaller) chambers. If you put them on a 350, you will need to watch compression ratio. 062 and 906 are 350 Vortec heads, arguably the best factory production casting heads ever; but, you need a Vortec-specific intake manifold to use them (don't let anyone try to tell you otherwise), and valve lift can be limited (depending on your cam, you may or may not have to do something about that). 462 and 461 would be the old "camel hump" heads without accessory holes and with soft valve seats - not recommended. Don't spend extra money to get them - just get Vortecs. Vortecs will make more power, anyway.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
NWAsonoma
Aug 18, 2015 05:45 PM
