bad injectors?
Old Dec 24, 2009 | 05:38 PM
ManicMechanic88's Avatar
Car: 1989 Chevy Camaro IROC Z Convertabl
Engine: 5.0L 305 w/TPI
Transmission: Stock 5 speed
Axle/Gears: Stock Posi Trac
bad injectors?
So I got my engine fired up, but the idle is still a little rough after setting the timing. I started disconnecting the injectors one at a time and noticed that my rpm's don't drop significantly when I unplugged the last two. But I also noticed that the other two cylinders in front of the bad set aren't quite pulling their weight. Would two bad injectors effect four cylinders? Any ideas what it could be?
Old Dec 25, 2009 | 06:56 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: bad injectors?
Ohm them.
They should be around 16ohms each.
mike_c
Aug 27, 2015 04:32 PM
Jae992
Aug 27, 2015 09:07 AM
86IROC112
Aug 21, 2015 07:20 PM
Bryan F
Aug 18, 2015 02:28 PM
