1991 camaro rs with 305 need help!!!
Old Dec 30, 2009 | 03:41 PM
white123's Avatar
i have a 1991 camaro rs with a 305, a month ago a starter wire broke and it sat for about 3 weeks before i could fix it and after i did, i started it and it sounded different and it idled to low....when you put it in gear it dies and if you try to throttle up fast it just dies...Can anyone tell me what's wrong with it???
Any advice would be helpful!
Old Jan 1, 2010 | 01:46 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: 1991 camaro rs with 305 need help!!!
is it a tbi or tpi?
Old Jan 3, 2010 | 01:54 PM
white123's Avatar
tbi
Old Jan 3, 2010 | 03:25 PM
alexsholly's Avatar
Car: 91 rs
Engine: 305 tbi
mine did the same thing i changed the battery cause it was old and i havent had a problem. i would try charging your battery see if tht helps any
Old Jan 4, 2010 | 01:45 PM
white123's Avatar
k ill try that and see what it does
Old Jan 7, 2010 | 09:05 PM
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
if its not your bat check your alternator mine was going out and it did the same thing. and the starter may not be disengadging from the flywheel that was a problem if you get it started try keeping rpm's up and watch your volt gadge
jhawkeye
May 25, 2022 06:33 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
