PF1218 Question
Old Dec 31, 2009 | 08:18 PM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
PF1218 Question
AC Delco makes a Pf1218, 1218F, 1218CL, and 1218FCL...what're the differences??
Old Jan 3, 2010 | 10:04 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: PF1218 Question
FILTER,OIL
Part Number: PF1218
Product Notes:
[Duraguard-Oil Filter]; 2WD ; w/ anti-Drain back valve ; 115mm long
Per Vehicle: 1; Years: 1996-1999
FILTER ASM,OIL (CLASSIC)
Part Number: PF1218CL
Product Notes:
[Classic Design Oil Filter]; 2WD ; 130mm long
FILTER ASM,OIL
Part Number: PF1218F
Product Notes:
[Durapack-Oil Filter]; 2WD ; Bulk pkg, qty 12 ; w/ anti-Drain back valve ; 115mm long
Part Number: PF1218FCL
Product Notes:
[Durapack Classic Design-Oil Filter]; 2WD ; Bulk pkg, qty 12 ; 130mm long
EDIT: To sum it up, the "F" is bulk pack part number and "CL" is the Classic design that is 130mm long verses 115mm and does not include the anti-drainback valve.
Side note: These fit trucks & vans and will be too close to the ground on a 3rd gen which takes an 81mm long filter.
Old Jan 6, 2010 | 03:32 PM
wdigitog's Avatar
Re: PF1218 Question
Thanks! That answers all my Q's!
Old Nov 15, 2013 | 12:27 PM
92GTA's Avatar
Re: PF1218 Question
I found this thread doing a search. I've been using the PF1218 ever since the original PF25 was discontinued years ago.
It is a long filter however the oil pan is still lower that the filter. I buy the Royal Purple version of the 1218.
I just didn't want anyone to read this and think it's too low to use. I very much like the fact it's a much higher capacity filter than the one that so called replaced the 25, the 454, which is even shorter.
Alex
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
