Weird start up problem? Help
Old Jan 5, 2010 | 04:27 AM
dealbatony's Avatar
Car: Trans Am
Engine: V8 350 TPI
Okay so maybe on Friday I filled up on gas from arco(emergency gas) and my car started doing this thing where as soon as I started the car it was on but the rpm would go in n out, in n out..n when I press the gas it wouldn't rev at all it was on like a weird stand by mode..and so I figured it wa the bad gas or something cus I usually fill up at shell
n today on my way to work my car went dead after I turned it off..the radio n everything still worked but it wouldn't turn on I figured my battery died so I got a jump n as soon as I turned it on it did it again..n so I let it get more charge n it ran fine..
I'm thinking maybe it's the battery that's giving me the problems but I've also noticed that if I'm drivin n If floor it it'll rev up to speed but it won't hold the rpm it'll go away n pick up speed but it's not due to the transmission shift..
I heard maybe it could be my fuel pump??Or dirty injectors?
Anyone ever heard of a case like this??
Old Jan 5, 2010 | 09:37 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Weird start up problem? Help
First I'd get the battery or alternator issue resolved. Then I'd change out the fuel filter and see if that helps. Everyone has talked about "bad gas" since the day the first dinosaur died - but in reality most all gas is the same gas, just different detergents as additives - all the gas in the US travels through the same pipeline system from the ame refineries - and only real differences are what additives are added after it reaches the local tank farms for distribution to the stations.
Old Jan 5, 2010 | 10:07 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
check the fuel preasure
Old Jan 7, 2010 | 12:13 PM
dealbatony's Avatar
Car: Trans Am
Engine: V8 350 TPI
So last night I tried to start up the car it started b stayed on for maybe 10-15 seconds then it started stumbling n turned off and after that it wouldn't turn on =/
Old Jan 7, 2010 | 06:20 PM
Car: 1992 RS
Engine: Carbed 350
Is the fuel pump running?
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
sreZ28
Aug 14, 2015 07:48 PM
92camaroJoe
Aug 13, 2015 06:07 AM
