wont idle please help
Old Jan 6, 2010 | 02:06 PM
BigM's Avatar
i have a 92 camaro rs tbi with a 305 and ive replaced the starter, battery, beveled out the catalytic converter, still it doesnt idle, then i replaced the throttle position sensor still nothing, i fixed the vats cuz that screwed up, and then i replaced the oxygen sensor still it sputters and seems like its starving for air. I start it up i pump the gass it sputters and then revs and then i let go of the gas and it shuts off, any suggestions on what the problem is
Old Jan 6, 2010 | 02:58 PM
BigM's Avatar
Re: wont idle please help
think it could be the timing or the fuel pump or something, someone help me out lol
Old Jan 7, 2010 | 10:50 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
sounds like you have some mechanical sense
advance the timing and see if that helps
check the fuel pressure
look at the spray patern of your injectors
how many miles on that timing chain
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
