My Build Combo
Old Jan 7, 2010 | 08:11 PM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
My Build Combo
Hey guys, Im building an engine and im curious if you can give me a rough guess on power and streetablity. Here are the parts that I have.
A Fresh 010 350 block punched .030 over with unknown kb hyper pistons.
A Crower Beast Cam. 288/298 Duration, 444/467 gross lift, 1800-6000 rpm range.
Patriot Performance vortec style heads, 2.02/1.60 valves, 64cc chambers, .575 lift springs.
Jegs aluminum 1.6" roller rockers
Edelbrock rpm intqake
Holley carb 760cfm
t56 tranny
4.56 gear.
What do you guys think?
Old Jan 7, 2010 | 08:25 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: My Build Combo
Think you posted three times too many.Your post count just went up by 20%
Old Jan 7, 2010 | 11:30 PM
scottd's Avatar
Car: 82 Z28
Engine: 350 .040 over
Axle/Gears: 3.73 rears
Re: My Build Combo
Power, 325-360 HP my guess.
Opinion....that carb is too much for a 350. May wanna stay in the 650 range.
Those gears are going to break you neck off the line.
Old Jan 8, 2010 | 09:17 AM
1badeagle's Avatar
Engine: 370 LSX
Re: My Build Combo
Sorry dont know how that happened.
Old Jan 8, 2010 | 09:20 AM
1badeagle's Avatar
Engine: 370 LSX
Re: My Build Combo
Even with 325 horse is should be a mid to low 13 second car correct?
Old Jan 8, 2010 | 10:19 AM
scottd's Avatar
Car: 82 Z28
Re: My Build Combo
Ive never clocked a car. My only point of reference is my highly calibrated 'butt dynometer'. I can tell you my old setup was plenty fast- .030 over, Edlebrock 600 carb and intake, open exhaust from headers to cherry bombs and a set of 3.73 gears. Those 3.73's were a HUGE improvement and REALLY launch me. Those 4.56's are going to amaze you. Im currently redoing my setup to include a set of Vortec heads, a .460 cam and a Holley 670. Based on my super technical parts analysis (asking the same question on other forums ) and Im going to be pushing a soild 350 hp. i dont know what my 1/4 mile time is (or ever has been) because my speedo has NEVER worked correctly.
Old Jan 10, 2010 | 02:08 PM
1badeagle's Avatar
Engine: 370 LSX
Re: My Build Combo
I Would be happy with 350 hp. That should be more than enough to romp on my buddies ls1/t56 swapped 3rd gen.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
Jorlain
Oct 8, 2015 01:57 AM
roysatikas
Sep 22, 2015 08:15 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
z28guy134
Sep 1, 2015 11:50 PM
