1989 camaro need HELP!!!!!
Old Jan 7, 2010 | 09:11 PM
bravepride70's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
My 89 camaro rs has a 305 tbi and it is running ruff at idle and acts like it is missing while running at high way speeds. Another problem i am having is when i put the gas peddel to the floor it wants to run good for about 2 seconds and cut out and die, sometimes it will shut off and sometimes it will come back on after dieing. the last problem i have with it is when i hit the brakes to make a rapid stop it will stall out. I Have a timing light and have it timed dead center. I have put new plugs, rotor, wires, and cap on it and just replaced the throttle position sensor thinking this would fix it but with my luck it didnt. I need your help, i hate to see my camaro like this. im not shure if this could be a part of the problem but i have a 91 brain and 91 tbi on it.
Old Jan 7, 2010 | 09:24 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: 1989 camaro need HELP!!!!!
Have you checked your fuel pressure?
Old Jan 8, 2010 | 06:16 AM
Car: 1989 camaro rs
Engine: 305 TBI
what would be the easiest way to do so??
Old Jan 8, 2010 | 11:29 AM
Well there's really no easy or hard way of going about it you just need a fuel pressure gauge thats designed for use on TBI equipped motors. Once you have it it should include directions on how to use it.
camaro11j
Sep 19, 2018 08:49 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
Derick15
Sep 17, 2016 05:28 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
antares57
Aug 6, 2015 07:47 AM
