Best heads Combinasion on a TPI
Old Jan 10, 2010 | 04:32 PM
camaro350tpi's Avatar
Car: camaro iroc-z 89
Engine: 383 HSR SC MegaSquirt
Transmission: tko 600
Axle/Gears: 9 Inch 3.75
hi all ! ived got a camaro 89 with tpi maf , i will tranfer the computor to speed density i think a map sensor is better with a modified engine. so my question is a have a steal ram intake with a zz4 cam on my 350 engine , i want to know what will be the best cylinder heads to but on my setup i have seen gm performence heads they call it lt4 and it gives 11.5.1 compression ratio suppose to be a upgrade to the lt1 , i dont know if it will be a good idea the have 11.5.1 compression ratio on a street/strip car . what you think guys
Old Jan 10, 2010 | 10:42 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You don't want LTx heads.
GM Fast Burns (Vortec style), Edelbrock Etec RPMs (Vortec style), AFR 195's, all decent heads. The AFR's would probably have the performance edge.
Old Jan 11, 2010 | 09:31 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Best heads Combinasion on a TPI
11.5 to 1 is kinda high for the street
I have 10.5 to 1 and I just squeek by
Old Jan 11, 2010 | 09:51 PM
Thanks to response guys ! so AFR heads will be a good chose but witch one will be best with a zz4 cam ?
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
