What is this on the parking brake cable?
Old Jan 11, 2010 | 10:21 PM
j79z28's Avatar
My 86 IROC has 4 wheel disc brakes. What is the foam piece that is on the drivers side emergency brake cable for? It moves freely on the cable, and I was wondering its function and where it is supposed to be located.
Thanks!
Old Jan 12, 2010 | 07:01 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: What is this on the parking brake cable?
IIRC, it's a vibration dampener, which is supposed to be "fixed" over the axle.
JamesC
Old Jan 12, 2010 | 09:29 PM
j79z28's Avatar
The emergency brake cable is secured to the axle already. This "foam piece" just pushes up against the small bracket that secures the emergency brake to the axle? I just did a brake job, and am trying to put things back correctly.
Thanks for the reply.
Old Jan 12, 2010 | 09:35 PM
JamesC's Avatar
I was thinking, perhaps incorrectly, that the 'foam piece' was in a fixed position on the cable itself (over the axle). A search might turn up a pic. Found one:
https://webdisk.ucalgary.ca/~jmknopp...th%20tires.jpg
JamesC
Old Jan 13, 2010 | 06:41 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Just there to keep it from making noise if it bounces around a bit.
Old Jan 14, 2010 | 08:58 PM
j79z28's Avatar
Hi James,
Yep, thats the foam piece I was referring to. Thanks you guys for your input.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Eric-86sc
Apr 3, 2016 03:52 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
