head gasket question
Subscribe
Jan 15, 2010 | 01:10 PM
I am in the process of putting my engine back together and got a gasket kit from fel-pro. I'm just looking for reassurance that I DON'T need to put a gasket sealant on the head gasket? Also, does it matter which side is up? The directions that came with the gasket kit didn't specify.
Reply 0
Jan 15, 2010 | 01:40 PM
Re: head gasket question
No sealant needed. Look on the face of the gaskets as sometimes they will say "UP" on them.
Reply 0
Jan 15, 2010 | 02:11 PM
I didn't see any markings that said UP only thing on there was the model number. Here is the set I got:
Reply 0
Jan 15, 2010 | 04:39 PM
writing goes up.
Reply 0
Jan 16, 2010 | 04:07 PM
As a reference, I use the bore "O" ring.
If you feel with your finger on both sides of the head gaskets you'll notice that one side's ring sits higher than the other side. That's the side that goes toward the head.
Absent any indication on the gaskets as to which side should face up OR an instruction sheet accompanying the gaskets, that's the way I decide.
Some may say it doesn't matter, but I continue to do WHAT WORKS.
Jake
Reply 0
Subscribe
