high idle hot 85 t/a 305 tpi
Old Jan 16, 2010 | 10:05 PM
thetaman85's Avatar
Car: 85 Firebird Trans Am
Engine: Rebuilt 305 Carb
Transmission: Built 700R4
Axle/Gears: The unfortunate Open Diff, 3.23
on my 85 t/a 305 tpi when i start the car cold (i.e. in the a.m.) it idles fine-right where it should- but if i drive it somewhere and start it when its still relatively warm (like at school maybe 6-7 hours later) or any sooner and the idle goes right to and stays at about 1500 rpm if i try to kick down the idle it will either stay the same or go up slightly. but if i wait until the next morning it is fine again. when i look under the hood i can see bubbles rising up through the tube on the inner side of the coolant bottle, anybody know what this could be? i was thinking maybe the thermostat could be bad but im not exactly sure, it was a small problem but is now more frequent and i hate putting the car into gear at that high of an rpm. thanks in advance for your help
Old Jan 17, 2010 | 08:55 AM
Vader's Avatar
Re: high idle hot 85 t/a 305 tpi
The "obvious" culprit is the IAC. It's never a bad idea to remove and clean it, as well as cleaning the throttle body bores and plates.
The other points to inspect are potential sources of vacuum leaks, such as the PCV, all hoses, brake power booster, EGR, gaskets, and injector O rings.
Old Jan 17, 2010 | 09:36 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
um
bubbles in the tank means you need to have better gauges first of all
you are overheating
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
