Vapor lock or bad fuel pump or wiring?
Old Jan 13, 2010 | 06:32 PM
tslsa28's Avatar
Car: 91 RS and Jaguar XJS
Engine: ZZ383 with Mini Ram
Transmission: Tremec 3550
Axle/Gears: 3.42 with Tru Trac
I have a 1991 RS that I converted to multiport with Street and Performance's integrator. It is a ZZ383 with TPIS Mini Ram and 32# injectors with adjustable fuel pressure regulator at 45#. It makes about 380 rwhp and I had to put a 255 Walbro fuel pump in it as it was running out of fuel on the dyno pulls at high rpms. If it gets warm and is low on fuel, sometimes I can hear the fuel pump start to whine then it starts to stall. If I run it at heavy throttle and high rpms, it will keep running but as soon as it gets to lower revs and lighter throttle, it will completely stall and won't start unless I add fuel or let it completely cool down. I have had three fuel pumps in it and have insulated all the fuel lines anywhere close to sources of heat and the problem has never changed. The whining fuel pump must be the key but I don't know why, any ideas? Thanks.
Old Jan 13, 2010 | 06:59 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Vapor lock or bad fuel pump or wiring?
Well the intank fuel pump is kept cool by the gas, running low on gas all the time isn't good.
If your gonna run it low on gas all the time for weight, get a smaller racing type tank.
Old Jan 14, 2010 | 11:38 AM
tslsa28's Avatar
I could do that but it seems to not be addressing the problem. I think there is a problem and I am trying to identify it. Do you have any other ideas?
Old Jan 14, 2010 | 01:29 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
All Pumped Up And Nowhere To Flow
Monitor the fuel pressure immediately after the pump.
If it drops it’s drawing air.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime, and the nitwits that need headlights for a little rain
Old Jan 14, 2010 | 01:43 PM
tslsa28's Avatar
Re: All Pumped Up And Nowhere To Flow
Do you mean air from the gasoline boiling? I know it's not running out of gas as it has happened with a lot of fuel in the tank. What would cause the fuel pump to make noise before it happens? It sounds like it's deadheading.
Old Jan 14, 2010 | 02:17 PM
NINÅ's Avatar
Transmission: 765R4
No, the fuel in the tank is not boiling.
However if it was deadheading you would see it on the close-to-the-pump gage I recommended.
Happy Racing!
Old Jan 16, 2010 | 01:04 PM
tslsa28's Avatar
Does anybody think running the fuel pressure higher than stock can put more stress on the fuel pump and cause it to cavite when it gets very warm?
Old Jan 16, 2010 | 01:54 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
fuel pump sounds like to be the problem (usually doesn't do that with aftermarket pumps)....I had problem with vapor lock when warm as well. Higher than stock fuel pressure does more stress on pump for sure.
I would replace pump (with another good performance one)....then change your fuel filter (and do so every other oil change, they are cheap and usually are cause of burning out pump), change the gas tank vent (located in front of fuel tank, drivers side, gray vent attached to hose to top of tank), then a good trick to do is buy a muffler heat sheild and place it between tank and muffler to help keep some of heat off tank. Also the wiring inside tank sometimes goes bad, inspect that as well, and ALWAYS keep at least 1/4 tank or more of fuel in.
Old Jan 17, 2010 | 09:30 AM
Vader's Avatar
A typical TPI/EFI system operates its fuel lines at about 37-44 PSIG. Using 44 PSIG as a sample operating point for calculations (3 BAR), the temperature for gasoline to vaporize and create a "lock" in such a pressurized fuel line would have to be close to 160ºC (320ºF). If that were the case, I'd be more concerned about the plastic and other things dripping off the bottom of the vehicle. Even the lowest octane winter blend gasoline with a Reid Vapor Pressure of about 13.5 would require about 140ºC to overcome the 44 PSIG of the pump.
True vapor lock, as was suffered in older vehicles with engie mounted mechanical pumps is all but nonexistant in EFI systems with the pump in the tank. Fuel under atmospheric pressure could easily vaporize in a fuel suction line at relatively normal temperatures and prevent the mechanical pumps from sucking liquid fuel. That just doesn't happen in pressurized EFI systems.
Old Jan 17, 2010 | 10:38 AM
tslsa28's Avatar
Thanks. I already have a new fuel filter, a new fuel pump, a new vent, and have insulated the muffler, heat shield and exhast pipe. I think I will go back to a stock fuel pressure regulator since I'm going to do some dyno tuning for the new engine. This hopefully will take some stress off the fuel pump and if I remember correctly, I never had this problem before I went to an adjustable fuel pressure regulator. Thanks for the input.
Old Jan 17, 2010 | 10:39 AM
tslsa28's Avatar
Thanks for the numbers on vapor lock, it must be related to the fuel pump. Please see my previous post.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Jae992
Aug 27, 2015 09:07 AM
Newguy91rs
Aug 7, 2015 09:51 PM
