Fuel Pump Access Door
Old Jan 17, 2010 | 11:55 AM
gregh92's Avatar
I have seen many posts about creating a fuel pump access door in the floor of the car in order to change the fuel pump easily. Being a competent metal fabricator I am going to go this route as I am confident I can produce a very professional looking job. The only thing that has me stumped is what tool to use to cut the steel fuel lines safely. It doesn't appear to be enough room to use a tubing cutter.If anyone has done this job before I could sure use some advice.
Old Jan 17, 2010 | 03:10 PM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
Re: Fuel Pump Access Door
I used wire cutters to chew the lines apart. After they were apart I removed the assembly and cut the nasty ends off with a dremel while I was away from the tank.
Old Jan 17, 2010 | 04:27 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Hey greg, can you post pics of the project pls? that's an important "mod" that will save a lot of time when the time comes. Thanks.
Old Jan 17, 2010 | 06:21 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
My apologies for the hijack.....
I'd never do this, but I was wondering how big of a hole in the floor is necessary?
I'm wondering of one of those locking doors that came with those old school pick-up truck auxiliary tanks would work?
Old Jan 17, 2010 | 06:28 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
end of page 2 and page 3 have pics, measurement and all you need to know. a quick search would find it, not even a search its still ont he first page of fab
https://www.thirdgen.org/forums/fabr...cess-hole.html
Old Jan 17, 2010 | 10:49 PM
Davidgou's Avatar
Ok, so I just spent the last 2 hrs reading through this thread and found some VERY STRONG opinions on the subject. I don't think I would ask any questions here if I ever attempted such a "mod". Thanks for the info though.
Old Jan 17, 2010 | 11:17 PM
Stephen's Avatar
Car: 87 GTA
Yes. There are some very strong haters about this mod. I still see it as correcting a factory oversight.
I just wonder if they hate the cars that came this was.....FROM THE FACTORY? Do they see the designers as "dumb" for providing an access door?
Old Jan 18, 2010 | 09:08 AM
gregh92's Avatar
Yes I will post picks if I do this job. However so far the only suggestion I have gotten about cutting the fuel lines is using wire cutters to chew them apart. I will not do that or this job altogether if I cannot do it cleanly and neatly.
Old Jan 18, 2010 | 09:40 AM
Davidgou's Avatar
The previous owner did mine "the right way" as some say here. So hopefully I won't have to in this life...
Old Jan 18, 2010 | 07:02 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
if the car came with the access, there is no problem and i can say confidently that nobody would have an issues with it.
most of the hatred of this "mod" is when people say this is the "right way" to swap a fuel pump. No, is this application the "right way" is to drop the axle. Cutting the hole is a bit of a lazy method for most people. But again for other people its the only way because of a lack of tools and equipment to do it themselves, and/or the lack of money to pay somebody to do it for them, and for this i cant blame them.
The argument is made over and over again, and honestly, with the proper tools, it doesn't take more that a couple hours to do the job by dropping the axle.
Cutting the fuel lines is the hairy part, a lot could go wrong there, then reconnecting the lines could be hazardous if you dont keep in mint the pressure involved. the pressure line on the TPI cars to be done with a flare, or high pressure hose, clamps, and the tubing bubbled on the end to prevent the hose from pushing off.
The other propblem is rust. Witohut properly sealing the cut, on both sides, you can invite rust that is already an issue on these cars.
Personally, i would never cut the access door. Unless the car is a racecar that requires frequent servicing of the pump.
The factory pumps have lasted 20 years in some cases, so if you get a good pump the odds that it will live another 20 are pretty good.
In the end, do what you want, its your car, and thats all that matters.
-Phil
Old Jan 18, 2010 | 07:04 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
you can use a mini tubing cutter. remove the lock ring form the sender, then it will come out of the tank enough to get the tubing cutting on the lines, or so im told. Using a pair of diagonal cutting pliers to cut the lines is just retarded, not sure whos idea that is/was. Might as well cut it with a hammer and a screwdriver at that point...
Old Jan 18, 2010 | 09:19 PM
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
Why is cutting the line with wire cutters retarded? It is fast effective and after the cut is made you can pull the lines out and trim the chewed up part off with whatever you want. You will loose about 1/2" of damaged hardline after the trim but you will need to trim off more than that to fit a union in.
Double hack job ???
IMO wire cutters are safer than other options that will work.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
