1982 chevy camaro choke light on
Old Jan 17, 2010 | 08:07 PM
DPALz28's Avatar
Car: 1982 CAMARO
Transmission: 3 SPD AUTO
ok i have a 1982 camaro with a 350 in it. the car starts perfectly fine but when i try and drive it the choke light comes on and cuts the car off? not really sure what the problem is. any ideas on what the problem could be?? all answers will be appreciated thanks
Old Jan 18, 2010 | 01:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Do you have a stock induction system on, or has it been changed?
Do you know if your choke heater wire is hooked up to the choke thermostat?
Old Jan 18, 2010 | 07:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 1982 chevy camaro choke light on
If the choke light comes on at the same time as the engine dies, then it's lighting up because the alternator is no longer charging when the engine stops.
Vintageracer
Jan 10, 2020 05:33 PM
TheJoeY88
Dec 31, 2016 07:30 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
