combo question
Old Jan 18, 2010 | 11:53 AM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
combo question
How do you think this would work out?
This engine : http://www.sdpc2000.com/details/scog...nter/sd360vtpi
but instead of using edelbrock runners, I'd being using SLP runners, ported plenum and I have a procharger kit that I'd like to run on it. I also have a nitrous kit but I don't think I want to blow the poor brand new engine.
This procharged engine would replace my cousin's 305 tpi that was mostly stock with headers and exhaust, airfoil, and AFPR.
Will this engine take 8 psi of intercooler boost? I am assuming so seeing as that a stock engine can take the 12 this kit used to put out. Am I seeing this the right way? By the way, this is a budget build that we want to do for less than 6K and don't want to have to much down time.
Old Jan 18, 2010 | 01:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I believe that engine has hypereutectic pistons. Not the best choice for power adder. Cast actually work better with power adders than hypers do.
Old Jan 18, 2010 | 02:00 PM
all4u's Avatar
Car: Firechicken
Re: combo question
Are you saying then, it would be a bad combo? How much boost do you guess the engine could take?
ydnar417
Sep 23, 2015 05:57 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
