timing cover question
Old Jan 23, 2010 | 04:00 PM
89RSTBI's Avatar
Car: 89 RS, 93 Z28
Engine: Vortec 350 TBI, Lt1 6 Speed
I know this may sound like a stupid question but I was wondering if you can change the plastic timing cover that comes on the Vortec 5.7l engines with a aftermarket aluminum cover or do you have to stick with the plastic covers for this engine?
Old Jan 23, 2010 | 06:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: timing cover question
You can use any timing cover you like.
Old Jan 23, 2010 | 06:50 PM
89RSTBI's Avatar
Car: 89 RS, 93 Z28
thank you, that is what I thought but wanted to be 100% sure before I changed it from the plastic cover to something better. I didn't know if there would be sealing problems with any other cover or not
Old Jan 25, 2010 | 10:27 AM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
How 'bout one off a Chrysler 426 Hemi? LOL
Jake
Old Jan 27, 2010 | 03:07 PM
Pocket's Avatar
Car: 91 Trans Am
The reluctor ring has to be removed as it wont fit behind a conventional cover. It slides off
Be aware the vortec balancer has .125" shaved off the rear for the reluctor ring thickness. Belt alignment will not be correct with this balancer and no reluctor. Use a conventional SBC unit
Old Jan 27, 2010 | 03:14 PM
89RSTBI's Avatar
Car: 89 RS, 93 Z28
Thank you for that information I probably would have lefty it on and would be scratching my head when the cover didn't fit
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
