Whats the right size TB to run with my setup?
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
So whats goin to work best with my project. Its goin to be a 355, SR, 195AFR, 224-230- 53*- 112 cam setup. Will a 52mm TB or 58mm TB work best on the motor?
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: Whats the right size TB to run with my setup?
That motor would definitely benefit from a 58 mm, probably to the tune of 10 hp at peak. However, it's not a deal breaker to keep the 52 mm; Unless you absolutely need that last .05 sec of ET right away, take your time in looking for a good deal on a 58.
Car: 92 1500p\u 2wd
perfect, thanks thats what i was lookin for! im still lookin for heads and just won a SR via ebay! ill have to keep my eye out for a deal on a 58mm
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
52mm tb will flow something like 800cfm, the 58mm tb will flow 1000cfm. i doubt your car will peak above 6000rpms with the SR. you should be fine with the 52 but u could go 58mm.
got my 58mm tb brand new from proffessional products for about 218$ shipped
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
I was going to suggest the 52mm would be better. You won't loose any power or topend but also you'll get better throttle response. 800cfm dry is quite a bit. the stock 48mm will run 400 horse or something close to that....the 52mm is suffecient. Stay with it.
Car: 87 TA clone
48mmTB is fine upto 400hp with the addition of an air foil to smooth out the incoming air. but a 52mm would be fine.
Street Lethal
Aug 13, 2015 08:28 PM
knight72
Aug 10, 2015 09:32 PM
