i need some help
Old Jan 25, 2010 | 08:06 AM
Bomber's Avatar
Car: 92 Camaro RS
Engine: turbo 5.3
Transmission: th400 with 3500 stall
i need some help
hi , i have 2 questions to ask ,1 i just redid all the gaskets in my motor and i was wondering if i have to prime my oil pump before starting, 2nd question is i took out the computer because the car is not computer controllled anymore and i was wondering if there is anything connected to the computer like oil pressuer sending unit, fuel pump ect that i need to worry about, thank you!
Old Jan 25, 2010 | 08:11 AM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
Re: i need some help
you do the heads also? I would say no about priming. The bearings will have a coating, as well as the cam and lifters be pumped up. No worries. What year is the car, and year for the engine?
Oops 92 RS got it. Well your cooling fan won't turn on, unless it's been bypassed. Sounds like you have omitted the electric fuel stuff too yes?
Old Jan 25, 2010 | 09:25 AM
Bomber's Avatar
Car: 92 Camaro RS
Engine: turbo 5.3
no i havent done that, so the fuel pump is computer controlled? i took my car a long time ago to this guy and he put a wire on the fuel pump relay , and there was an orange wire that came from the computer
Old Jan 25, 2010 | 12:02 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
EVERYTHING will function as normal without the computer - the fan, the fuel pump, everything except the torque converter lockup on the 700R4.
I'm assuming it's been swapped to carb and thus no more computer. Fuel pump will not prime, but doesn't need to with a carb, as there is plenty of fuel in the carb bowls to start and run the car until oil pressure is built up enough for the oil pressure sending unit to power the pump.
Computer doesn't control the fan, the fan switch in the pass head controls the fan.
If swapped to carb, you need to make sure you have the proper geometry corrector on the carb linkage for the TV cable - otherwise you greatly risk frying the 700R4.
Old Jan 25, 2010 | 12:32 PM
Bomber's Avatar
Car: 92 Camaro RS
Engine: turbo 5.3
all of that has been done i just cant get the car to fire i did get starter fluid or whatever its called the car started but it will shut off after like a second or two and the fuel gauge and the oil gauge dont read anything
Old Jan 25, 2010 | 12:46 PM
Car: 1992 RS
Engine: Carbed 350
And you got a return style fuel pressure regulator right? Can you hear the fuel pump running with the key on?
Old Jan 25, 2010 | 01:05 PM
Bomber's Avatar
Car: 92 Camaro RS
Engine: turbo 5.3
yes it does , see the car used to run fine before but since the computer had nothing to do with it i took it out to clean up the engine bay a little , and no i dont hear the fuel pump prime when i turn it on at all , i was thinking that the fuel pump went out on it
Old Jan 25, 2010 | 01:15 PM
Car: 1992 RS
Engine: Carbed 350
OK - run 12 to the fuel pump and see if it runs then - then you'll know if it's a bad pump. Since your relay has been screwed with and we don't know exactly how, I'd go under the car, remove the plug from the Oil Pressure Sending Unit (just above the oil filter), and cut the two larger wires from it (with enough room to reconnect of course), and touch them together. This will make the pump run if it's working - key does not have to be on for this. And make sure the fuse tucked in the fenderwell beside the battery is good.
