Oily spark plugs?
Old Jan 25, 2010 | 08:24 PM
Kwijybow's Avatar
Car: 1987 Z28 Camaro (T-tops)
Engine: Carb'd 305
Transmission: 700R4 (auto)
Axle/Gears: Posi / 3.27
Oily spark plugs?
So I suspect I already know what is wrong but I wanted to double check with you pro's out there. I checked my plugs today (for the hell of it) and found only 1 had a noticable amount of oil on it. My car's engine is a mostly stock (only changes I've made / I know about are plugs and an Edelbrock 1406 carb) 305. What do you think? Gaskets?
Old Jan 25, 2010 | 08:53 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Oily spark plugs?
How many miles on it? Just a " noticeable " amount..?.. as in a drop or two, more//less?
Check the PCV. Valve seals for that cylinder.
Maybe premature, but can you do a leak-down test?
Old Jan 25, 2010 | 09:19 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Where, exactly on the plug did you find the oil?
Jake
Old Jan 25, 2010 | 09:24 PM
Kwijybow's Avatar
Engine: Carb'd 305
The engine has about 240k KM's on it but it was rebuilt at about 180k. By "noticable" amount, I mean enough to cover the tip of the plug entirely. The thing I found weird was there was only oil on that 1 plug, the others were clean.
Old Jan 25, 2010 | 09:39 PM
ymenic's Avatar
Car: 1982 Camaro z-28
Engine: 307
Transmission: th-350 with stage 2 shift kit
Axle/Gears: stock
Valve steam seals? How much oil are you burning?
Old Jan 25, 2010 | 09:50 PM
JakeJr's Avatar
Axle/Gears: 3.07
My first thought, too, if it's on the porcelain.
Jake
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
