Does compcam 853-16 work in -90 roller block?
Old Jan 26, 2010 | 09:59 AM
stinger32's Avatar
Car: Trans am GTA 1990
Engine: 383
Transmission: TH700R4
Axle/Gears: stock
As topic can I use 853-16 roller lifter in a orginal. roller block -90 1pc seal?
Compcam writes: These lifters are for use with all series of Comp Cams hydraulic roller cams or as performance replacements for stock hydraulic roller lifters. Make sure the lifter is correct for the block used.
Old Jan 26, 2010 | 11:31 AM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Re: Does compcam 853-16 work in -90 roller block?
No, those are the wrong ones. Those are for a retro-fit applications for engines that came WITHOUT a roller cam, 86 and earlier.
You need 875-16 lifters. "Small Block 305 & 350. For use in blocks originally equipped with hydraulic roller cam ('87 to present)".
It's a good idea to always call the company when making these kinds of choices. Comp's # is 1-800-999-0853.
Jake
Jake_92RS
Jan 28, 2020 10:37 PM
midge54
Dec 27, 2019 04:14 PM
camaro71633
Sep 1, 2015 10:24 AM
BrianI
Aug 9, 2015 11:52 AM
anesthes
Aug 8, 2015 09:37 PM
