3rd Gen Serpentine System Qs
Old Jan 30, 2010 | 05:20 PM
badazz81z28's Avatar
Hello,
I have aqquired a 3rd gen serpentine system and wasnt thinking when it was taken apart.
1. Does anyone have a diagram of where all the bolts go?
2. Is the water pump a short or long design?
3. Is the PS pump pulley pressed on or just held on by the hex shape bolt?
Thanks a ton!!
Old Jan 30, 2010 | 09:18 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 3rd Gen Serpentine System Qs
The following may be helpful (long, reverse rotation water pump):
https://www.thirdgen.org/forums/afte...rsion-kit.html
JamesC
Old Jan 30, 2010 | 11:23 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
the power steering pump pulley is press on. the hex fitting inside the shaft is to help prime the pump by spinning it counter clockwise. ALSO i think, i not sure, but GM did press on in case of shaft lockup. common on hydraulic pumps
Old Jan 31, 2010 | 10:40 AM
Any tips to pull the PS Pulley? Im going to to see if Autozone has the tool.
Old Jan 31, 2010 | 11:06 AM
yeah get the puller at autozone, like 20 bucks to rent, it looks like this pic ive included. instructions on the box. . Ive included a link to help aide in the removal, the process is the same as in the link regardless if it for a jeep, it works on our pumps too. http://www.stu-offroad.com/steering/...pspulley-1.htm
to install the pulley, theres a tool included in the autozone puller kit that threads into the powersteering pump's shaft, evenly and slowly and evenly turn a adjuster nut till it wont turn and the shaft is flush with the pulley like how it is before removal.
Attached Thumbnails 3rd Gen Serpentine System Qs-41hiel6sv3l._sl500_aa280_.jpg   3rd Gen Serpentine System Qs-pulley_remover_01.jpg   3rd Gen Serpentine System Qs-psp-5.jpg
evilstuie
Jan 9, 2020 08:29 PM
Fast355
Dec 2, 2016 06:33 PM
Warlocksirix
Sep 3, 2015 12:26 PM
mustangdmurder
Aug 21, 2015 07:17 PM
jahblah
Aug 12, 2015 05:54 PM
