backfire while starting?
Old Feb 2, 2010 | 04:34 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
My car has started to do something odd. Just in the last couple off weeks it sound like it's backfiring while it's starting, usually twice, sometimes once, and only the first start of the day.
After it starts, it seem to run just fine
it's a 2.8 V6, any idea of what I should check first?
Old Feb 2, 2010 | 10:12 PM
58mark's Avatar
Re: backfire while starting?
bump.... things sure do get buried fast
Old Feb 8, 2010 | 06:21 PM
58mark's Avatar
let's try this again... little help?
Old Mar 6, 2010 | 12:07 PM
58mark's Avatar
ok, I took apart everything above my intake manifold on my car. Replaced gaskets, replaced tips and o-rings on my injectors, checked all vacuum lines and replaced anything that looked iffy, and it still does it. Sometimes, it starts and sounds great, but sometimes it will backfire and surge and bog down like it won't start at all, but then eventually it fires up. The longer it's been since it had been started, the worse it is.
ideas?
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
dyeager535
Aug 28, 2015 08:10 AM
db057
Aug 22, 2015 08:17 PM
